Oct 5th, 2024, 3:47pm
Temperature Option in Analog Artist (Read 3616 times)
qiushidaren
I am a lovely
MOSFET!
Chengdu
Mar 09th, 2007, 12:40am
I have a question to ask you, that is, you know when I am using Cadence, in Analog Artist, there is a Temperature opition in Setup, what I wanna know is this Temperature is what kind of temperature, is it the environment temperature where the die is operating, or something else?
Terry
bharat
Re: Temperature Option in Analog Artist
Reply #1 - Mar 12th, 2007, 2:11am
Yes it is ambient temprature.
monte78
Reply #2 - Mar 12th, 2007, 2:19am
I think it's the temperature of the environment, but you have to consider that the die will probably work at higher temperature, so usually you can consider this temperature as the die temperature (otherwise you will need some transistor models that can include self-heating).
qiushidaren wrote on Mar 9th, 2007, 12:40am:
Terry
adesign
Reply #3 - Mar 12th, 2007, 2:37am
This is environment temperature and the die temperature is higher than this.
Reply #4 - Mar 12th, 2007, 8:57am
The temperature of a particular device k is
    tk = temp + trisek
where temp is global and trisek applies only to the particular device.  With integrated circuits, one generally uses temp to represent the average die temperature and trisek to represent the deviation of the device temperature from the average. In most cases the individual device temperature is not important, so trise is not used.
qiushidaren
I am a lovely
MOSFET!
Chengdu
Reply #5 - Mar 13th, 2007, 10:23pm
So, looks like it's the die temperature rather than the environment temperature?
