Oct 5th, 2024, 5:20pm
Shielding on differential lines (Read 1600 times)
fonseca.ha
UK
Mar 08th, 2007, 3:53am
I have an audio sensitive differential signal to route accross the chip, between a driver and a receiver. This line is to be shielded but I have one doubt. Is it better to connect the shield to the ground on the driver side or on the receiver side?
Thank you
chase.ng
penang/malaysia
Re: Shielding on differential lines
Reply #1 - Mar 12th, 2007, 8:09pm
The shielding ground should be connected at the receiver side.
Chase
View Profile chase.ng   IP Logged
