Jul 16th, 2024, 7:29am
Offstate transistor model (Read 2734 times)
ee484
Mar 09th, 2007, 10:24am
Dear all,
What are the mechanisms that cause off-state finite resistance of MOS (i.e., NMOS)?
For example, a simple nmos switch case, is there any charges (i.e., intrinsic or induced charges when one of terminal is at high voltage (i.e.2V)) between source and drain? Can I assume that off-state finite resistance is mainly due to the resistance between two diffusions?
Or, another theory -The mainly responsible for off-state finite resistance of MOS is from the resistance between souce/drain and substrate contact. (Ptap for NMOS case, bulk contact).
any references and comments are welcome.
Last, but not least, can I trust spice for off-state mos model??
Best,
B
Re: Offstate transistor model
Reply #1 - Mar 13th, 2007, 7:28am
ee484 wrote on Mar 9th, 2007, 10:24am:
This really is a question of whether you can trust your foundry to do an adequate job of extraction in subthreshold.  I would expect that you can, particularly for digital designs, the off-state (subthreshold) leakage is of critical importance when you're trying to calculate the static power dissipation of  your design.
