Hi Chase,
Well, the capability is in MMSIM611 - so you could use that with IC5141. There's a parameter "sampling=lhs" which can be added to the monte carlo statement in the netlist, but the problem is that the monte carlo GUI doesn't provide support for specifying arbitrary parameters. So I guess the only option is to use Simulation->Create Input Files, edit the input.scs to add sampling=lhs, and then Simulation->Run.
