Matthieu
I had the same problem for a buck. -> I don't know if it is the more suited solution but to study loop stability, spectre PSS/PAC simulation can do the work. It will give you some insight into transfer function Gain/Phase of switched part. -> IOR have a very interesting application note about how to compensate buck converter, I don't know if it can apply to boost converter. -> You can refer to this topic: "DC/DC Buck's Phase Margin analysis using spectre ?" in "High-Power Design" forum
Matthieu
