Jul 4th, 2024, 12:47pm
command to convert HSPICE text file to Spectre (Read 3490 times)
avlsi
singapore
Dec 25th, 2006, 8:54pm
       Please let me know ,if there is a command in Cadence Environemnt to convert HSPICE text file to Spectre.Please send me a reference also...
Thanks in advance,
avlsi.
Winners never Quit,Quitters never Win
Re: command to convert HSPICE text file to Spectre
Reply #1 - Dec 26th, 2006, 10:18am
spp
Reply #2 - Jan 15th, 2007, 7:18am
spectre can also read HSPICE/SPICE netlists natively these days (since MMSIM60 by default, or IC5141 with the +csfe command line switch). So there usually is no need to convert the syntax to spectre syntax.
avlsi
singapore
Reply #3 - Mar 7th, 2007, 10:36pm
Hi,thanks for the spp command.But in the Hspice file i have some equations,making the parameters updated automatically.These equations are unable to converted to spectre. It is saying a fatal error at that line of equation.
Hspice file is working pretty fine in the simulations.Please tell me how to proceed...
Reply #4 - Mar 15th, 2007, 6:21am
As I said before, you should be able to use the HSPICE syntax files directly in spectre these days (see my previous post in this thread). Did you try that?
