Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
May 3
rd
, 2024, 2:14am
Home
Help
Search
Login
Register
PM to admin
Design
High-Speed I/O Design
› CDR Clock
Previous topic
Next topic
CDR Clock (Read 3047 times)
Amit Singh
CDR Clock
Mar 19
th
, 2007, 12:05am
I am working a Clock data recovery circuit at 6.5G in 0.18um tech. Do i need to saturate the clock after the VCO, or is it ok to feed the sine clock to the phase detector.
Thanks for the help,
IP Logged
SATurn
Re: CDR Clock
Reply #1 -
Mar 21
st
, 2007, 10:28am
It depends on your PD topology. If it is based on SCL (source-coupled logic) topology, then it should be fine. Else, you are using CMOS gates in your PD, you should convert the levels to CMOS level.
SATurn
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
»» High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
