Aug 15th, 2024, 4:53pm
Pnoise transfer function different from PSS Vgain (Read 2476 times)
Bill Toole
Mar 28th, 2007, 11:13am
While simulating differential LNA I noticed that the gain reported by the Pnoise Transfer Function is significantly different than the voltage gain from a straight PSS simulation. The particulars of the circuit are Zin = 100 Ohm, Zout = 800 Ohm, Av(unloaded) =  29.4dB. The input port is set 60dBuV (1mV). I deliberately mismatch the input and output with Rs=800 Ohm and RL = 100 Ohms. The PSS sim reports a voltage gain of 10.33dB as expected but the Transfer Function from the pnoise sim is -2dB??? I cannot find in the manual how Pnoise calculates the gain. Any thoughts? Why is the pnoise gain so different than the PSS gain?
Frank Wiedmann
Munich, Germany
Re: Pnoise transfer function different from PSS Vg
Reply #1 - Mar 29th, 2007, 12:04am
See the section "Gain Calculations in Pnoise" in Appendix L ("Using PSP and Pnoise Analyses") of the SpectreRF User Guide (http://sourcelink.cadence.com/docs/files/Release_Info/Docs/spectreRF/spectreRF6....) and also Solution 11184824 (http://sourcelink.cadence.com/docs/db/kdb/2005/June/11184824.html). These are also the first links that come up when you search for "pnoise gain" in SourceLink.
Bill Toole
Reply #2 - Mar 29th, 2007, 8:17am
Thanks for the info. That helped Basically what it said is that the voltage gain is defined as Vout/Vin but the Noise gain is Vout/Vs so you have a badly mismatched case as I did with Rs=800 and Rin =100 there is an additional attenuation of the equivalent input noise source at the input of the DUT.
