Oct 18th, 2024, 12:40pm
14bit pipeline adc post-simulation problem (Read 1352 times)
ponderboy
Mar 31st, 2007, 11:30am
I'm designing a 14-bit pipeline ADC,it has a 4-bit first stage,using 16 comparators and a 105dB,2GHz BW two stage amplfier for MDAC,the sampling switch of the first stage MDAC is a bootstraped switch.after layout,I use assura to do RCX extraction.When using decoupled extract option,the post-simulation ouput from a ideal 14bit DAC got a 92dBc SFDR when woring at 85MHz.But when using coupled option to do parasitic capacitor extration,the SFDR drops to 81dBc at same sampling frequency and same input analog signal. I guess the lost of 11dBc may due to parasitic capaciotr coupled between  sampling capacior of MDAC,or from the nonlinearity of switch.what should i do?
