Hello all,
I am trying to design a signal generator for SOC.
From my little knowledge of designing.. I should design the oscillator and several others block for the signal generator.
I am not sure what is the problem of designing oscillator ...i.e issues that I should consider..
I am stuck on how to start the design. i.e better if I use the spice or straight away with mixed signal schematics ( in cadence).
What is your best suggestions?
My plan in the designing the oscillator would be using switched capacitor to replaced the resistor..
I wanted the signal generator to produced sine, triangle and square wave at frequency from near DC to 50 Mhz..
Anyone please give me soem suggection?? or guide for it??
and I am considering low power od SOC..
