Aug 15th, 2024, 10:59am
Problem of verilog-ams in Spectre (Read 4125 times)
smchiu
Apr 04th, 2007, 8:29pm
Hi everyone,
I have used the op-amp verilog-ams model on this website, and trying to use Spectre in ADE to simulate it. I have use the hierachy editor to select the verilogams view for this op-amp block.
However, when I tried to simulate it in the Spectre simulator, I got the following error:
Netlist Error: Unknown cell type for instance 'I8' in lib 'low_voltage' cell 'ideal_op' view 'verilogams'.
I8 is the block for the verilog-ams program. Low_voltage is my library's name.
I am very puzzled and I don't know what to do with it. Someone even suggests to me that perhaps Spectre ADE does not supprt the view type verilogams.
Please help. Thank you so much.
David.
Re: Problem of verilog-ams in Spectre
Reply #1 - Apr 4th, 2007, 8:42pm
That is correct, Spectre does not support Verilog-AMS. It supports Verilog-A.
smchiu
Reply #2 - Apr 4th, 2007, 11:36pm
Thanks Ken for your reply.
In this case, if I want to use Verilog-AMS, which simulator in Cadence would support that?
David.
Reply #3 - Apr 5th, 2007, 5:33am
AMS Designer.
