Bill Toole
Hi
I am wanting to find out if it is possible to develop frequency domain only models in verilog-A for spectreRF harmonic balance simulations. For example, I would like to create a model for an ideal DC block similar to the DC-Block component in ADS. In the frequency domain this should be simple - if the input frequency is DC, the output is zero otherwise the output is the same as the input for all other frequencies or something along that lines. I am not very familiar with verilog-A yet but I get the feeling that this may be more of a problem than I first thought. I am not asking for the code to do this just weather it is even possible before I dive into the water. If it is possible could you point me to a reference or example of some code for the frequency domain. Thanks in advance
