Oct 18th, 2024, 12:44pm
AGC (Read 6634 times)
aaron_do
AGC
Apr 09th, 2007, 6:28am
If i have an AGC which uses a piecewise log-linear VGA, how do i prevent the vga from going back and forth between two states? i.e. signal is higher than Vref so decrease gain => signal is lower than Vref so increase gain etc...
thanks,
Aaron
mg777
Re: AGC
Reply #1 - Apr 9th, 2007, 9:42am
Is it the Av versus Vcontrol that is quantized or is it the transfer characteristic Vout versus Vin that is piecewise linear? The two are different. As long as Av versus Vcontrol is monotonic it's OK.
M.G.Rajan
ACWWong
Oxford, UK
Re: AGC
Reply #2 - Apr 9th, 2007, 10:50am
aaron_do wrote on Apr 9th, 2007, 6:28am:
thanks,
Aaron
you use hysteresis....
aaron_do
Re: AGC
Reply #3 - Apr 9th, 2007, 7:01pm
thanks for the replies...
so the AGC is actually switching states back and forth slowly? Any good references?
thanks,
Aaron
ACWWong
Oxford, UK
Re: AGC
Reply #4 - Apr 10th, 2007, 2:18am
when i say hysteresis, i mean like how any household thermostat works, you need to offset gain up and gain down decision making...
i'm not sure about references... i've always designed my own AGC strategies.
mg777
Re: AGC
Reply #5 - Apr 10th, 2007, 10:12am
Can your system tolerate a steady state error between the AGC set point & actual?
M.G.Rajan
aaron_do
Re: AGC
Reply #6 - Apr 10th, 2007, 7:00pm
Actually i've never designed AGC before and I was just having some doubts. I'm not worried about steady-state error for the moment...I intend to implement two AGC loops. A coarse one and a fine one. Right now i'm looking at the coarse one.
What i want to do is have a peak detector and filter, then have a comparator bank to get about 6-8 control signals. They can select the gain level. So you end up with 9 gain levels (one is always set). So i'm worried that if i have say 10 dB gain differences, the output amplitude will osciallate by about 10 dB. I've read some papers but none of them seem to talk about that.
ACWWong, i'm starting to understand what you mean now by hysteresis. The idea had occured to me but i thought it would be too complex (i'm going for low power) to implement. Is there a simple way to do this?
thanks,
Aaron
aaron_do
Re: AGC
Reply #7 - Apr 10th, 2007, 7:42pm
Hi ACWWong,
thanks for the tip on hysteresis. I think I figured out how to get it working...
BTW if i need linear in dB, and i want to use a comparator bank, does that mean i need to have a dB linear scale of resistors? i.e. series resistors from VDD to GND with exponentially increasing values. I guess the other way would be to have an exponential peak detector...
thanks,
Aaron
ACWWong
Oxford, UK
Re: AGC
Reply #8 - Apr 11th, 2007, 1:57am
my opinion is to use exponential detector every time... i think a good google/IEEE search for limitter/RSSI designs will give you some ideas....
aaron_do
Re: AGC
Reply #9 - Apr 11th, 2007, 11:55pm
OK...sorry i made a mistake...it should be a logarithmic detector. No wonder i couldn't find anything on exponential detectors.
ACWWong
Oxford, UK
Re: AGC
Reply #10 - Apr 12th, 2007, 3:50am
oh course i meant log as well  ;)
