Jul 20th, 2024, 11:37am
How to avoid Parasatic resistance deletion (Read 6843 times)
Faisal
Apr 10th, 2007, 8:49am
Parasatic resistor "rs" has been deleted becuase its value of 2.4375 mOhm (R/MFactor) was smaller than minr.
I want this parasatic ressistance to be included in my simulation. How can I set MFactor or R or minR with Spectre Simulator.
Re: How to avoid Parasatic resistance deletion
Reply #1 - Apr 10th, 2007, 12:09pm
spectre -help options
see the part about "minr" (it's the last parameter in my version of spectre, but then there are some notes).
Reply #2 - Apr 11th, 2007, 7:07am
Do be careful about setting minr very low, because it can lead to convergence difficulties. See Ken's book http://www.designers-guide.org/Books/#Kundert-1995 page 24.
Faisal
Reply #3 - Apr 12th, 2007, 2:46am
Thank for the responses. I have a Cadence version 5.10.41.500.3.58.  I am using the Virtuso Analog Design Environment, the simulator is set to Spectre.
In Simulation->Options->Analog,  I can only find the gmin option but not the minr, in the resistance section.
Do I need to look some where else ?
Reply #4 - Apr 12th, 2007, 4:28am
I don't use ADE; I hope Andrew can help you with that.
You can also set minr on the model card for the device(s) you're concerned about -- eg, if you want to set minr for some very wide output devices but not necessarily for minimum-width devices.
Faisal
Reply #5 - Apr 12th, 2007, 4:48am
I am getting this warning for a very large size device i.e. pass transistor in the LDO.  In addition I also get this warning for a few normal size transistors.
A related question is how important is to model these parasatic resistances, when they are being deleted ?
krishnap
Reply #6 - Apr 12th, 2007, 5:55am
Is the parasitic resistance of the device model or  being obtained from the
Parasitic extraction from the layout?
Faisal
Reply #7 - Apr 13th, 2007, 1:10am
This is coming from the device model and not from the layout.
Reply #8 - Apr 13th, 2007, 6:31am
I believe minr only shows up in the "Resistance Options" section of the Setup->Options->Analog form if you're using an MMSIM version of spectre. However, it does seem to be supported in some IC5141 versions of spectre. You could always go to the bottom of the Analog options form and type in "minr=nnn" in the Additional Options field.
HOWEVER, the chances are that this won't work. Since local (model) minr is by default 0.1, setting it globally to something lower won't help - since it will already have been removed by virtue of the local minr.
Is it really going to make that much of a difference?
Reply #9 - Apr 13th, 2007, 6:42am
Andrew Beckett wrote on Apr 13th, 2007, 6:31am:
I've heard that resistance is quite important to model correctly for those LDO output devices ...
