JC
After doing pss/pnoise analysis, I want to see the plots about device current such as drain current. I have tried much time to find drain current, however I failed. My ocean script looks like as follow: ====================== ...... save('all) analysis('pss ..........) analysis('pnois.........) paramAnalysis(.........) paramRun() ====================== After run the script, I tried several commands such as "selectResult("pss_td")", "getData()","i("M1/D")".... Finally it didn't work.
Could you tell me how to get current data?
Thanks!
-JC
