May 19th, 2024, 8:43pm
How to display device current data? (Read 2420 times)
JC
Apr 10th, 2007, 3:19pm
After doing pss/pnoise analysis, I want to see the plots about device current such as drain current. I have tried much time to find drain current, however I failed. My ocean script looks like as follow:
save('all)
analysis('pss ..........)
analysis('pnois.........)
paramAnalysis(.........)
paramRun()
After run the script, I tried several commands such as "selectResult("pss_td")", "getData()","i("M1/D")".... Finally it didn't work.
Could you tell me how to get current data?
Thanks!
-JC
« Last Edit: Apr 11th, 2007, 3:11am by JC »
Re: How to display device current data?
Reply #1 - Apr 11th, 2007, 8:14am
I can't remember the specific OCEAN way of doing this, but you'll need to save the device currents - either the specific drain current or all device currents. Try setting this up in ADE and then dumping the OCEAN script to see what happens (Look at the Outputs->Save All form, and Outputs->Save->Select on Schematic).
