Sep 29th, 2026, 9:31pm
Pages: 1 2
performance analysis in ADE (Read 5404 times)
Pavel
Lausanne/Switzerland
Apr 10th, 2007, 11:25pm
Is there some possibility to do in ADE Cadence some sort of performance analysis, like in Orcad Spice.
Under performance analysis I mean dependence of some circuit parameter (gain, phase margin, etc.) from some component parameter (polarisation current, supply, component values, etc.).
For example, after making parametric analysis in AC, where parameter is polaristaon current, how can I get a graph of a Gain at 1 Hz versus polarisation current.
I searched in Cadence manuals, but nothing found.
Pavel.
Re: performance analysis in ADE
Reply #1 - Apr 11th, 2007, 5:36am
It sounds as if this might be spectre's "sens" analysis (which is a small-signal sensitivity analysis)?
Pavel
Reply #2 - Apr 11th, 2007, 5:58am
Thank for response Andrew
From which tool can I get acces to this "sens" analysis to see if it's that what I mean?
Regards.
Pavel.
Reply #3 - Apr 11th, 2007, 6:05am
Well, if you're using ADE, and have spectre as the simulator, sens will show up in the list of analyses. You might also want to read the documentation, via cdsdoc (or type "spectre -h sens" for a short help on the analysis.
Pavel
Reply #4 - Apr 11th, 2007, 6:32am
Ok, I found it.
It's not realy what I need.
In Orcad Spice it's easily.
First I do parametric analysis (AC for instance), second click on buton "Performance analysis" (or something like that), and then choose in opened window some performance function (for instance Gain at 1Hz).
Result is graph, where x axe - parameter value, y axe - performance function.
Does similar procedure exist in Cadence ADE?
Regards.
Pavel.
Reply #5 - Apr 11th, 2007, 6:35am
OK, I understand now. This is much simpler. You can either use the Direct Plot form to plot many things, or use the calculator to calculate a particular value. If the result of that calculation is a scalar value (e.g. phaseMargin, gain bandwidth, etc) then if you do a parametric sweep (Tools->Parametric Analysis) then it will plot that scalar value versus the swept parameter.
Pavel
Reply #6 - Apr 11th, 2007, 6:58am
Maybe there is some misunderstanding, but I didn't get desired graph, but many courbes on the same graph.
My approach was as follows.
In ADE
1. Setup AC analysis F1 ... F2
2. Cnoose output to plot - out1.
3. Run AC simulation -> V(out1) vs. freq appeared in WaveScan window
In WaveScan
4. Using calculator transformed V(out1) vs. freq in dB20(V(out1)) vs. freq
In ADE
5. Tools-> Parametric Analysis setup parameter sweep and run simualtion
In WaveScan
6. Several graphs appered in the form: V(out1) vs. freq, but not dB20(V(out1)) vs. freq
Where I was wrong?
Regards.
Pavel.
Reply #7 - Apr 11th, 2007, 7:01am
Pavel,
If you used the value() function to plot the amplitude at a particular frequency (say), it would then result in a scalar value - and so would be plotted against the swept variable.  Or you could use the bandwidth calculator function to find the (say) 3dB bandwidth.
In your case the calculator result is a waveform (not a scalar) in the case of a single run, and so when doing a parametric sweep, it can't plot it against the swept variable. Instead, it plots a family of curves - one per point in the parametric sweep.
Pavel
Reply #8 - Apr 11th, 2007, 7:25am
Now my approach was as follows:
In ADE
In WaveScan
5. Using calculator value function calculated dB20(V(out1)) at frequency 1 Hz (correct value appeared in WaveScan)
In ADE
6. Tools-> Parametric Analysis setup parameter sweep and run simualtion
In WaveScan
7. The same as before - several graphs V(out1) vs. freq
Best Regards
Pavel.
Reply #9 - Apr 11th, 2007, 9:44pm
That's because you're still plotting v(out), not the value at 1Hz.
If you use Outputs->To Be Plotted, it's going to just plot the whole waveform - and consequently a family of curves if you do a parametric analysis.
Instead, use Outputs->Setup, and click on the Open button (next to the calculator expression). Build the expression as before - which will be something like:
db20(value(VF("/out") 1))
and then hit the Get Expression button in the Setup Outputs form. Give it a name, mark it to be plotted, and then Add.
Now when the simulation has finished, it will auto plot the expression versus the swept value.
Alternatively, just build the expression in the calculator after the simulation, and hit the plot icon in the calculator - this will do the same thing.
It would be wise to spend some time reading the manual. Hit the Help button in the corner of the ADE window, or run "cdsdoc" from the UNIX window, or take a look at <instdir>/doc/anasimhelp/anasimhelp.pdf . These are very basic usage questions, and reading the documentation is a good place to start.
Pavel
Reply #10 - Apr 11th, 2007, 11:24pm
It works, thanks Andrew.  :)
Two small questions:
1. Official titre of document you mentioned in your message (....anasimhelp.pdf). In my setup help isn't properly configured, so I have to download help docs from our internal technical support site.
2. In my version of calculator there is no plot icon (plese, see the picture).
Best Regards.
Pavel.
Reply #11 - Apr 12th, 2007, 12:12am
Pavel,
The little graph icon to the right of the Append cyclic, and above the Eval button is the "plot" icon I was referring to. This will plot whatever you have in the calculator buffer.
Your first question wasn't really a question - so I'm not sure how you're expecting me to answer it?
Pavel
Reply #12 - Apr 12th, 2007, 12:21am
Andrew,
I mean title of document that figures on 1st page.
For example I have .pdf where on 1st page there is title
VirtuosoŽ Analog Design Environment User Guide
Is it the document what you mean?
Pavel.
Reply #13 - Apr 12th, 2007, 12:33am
Yes.
Pavel
Reply #14 - Apr 12th, 2007, 1:39am
Andrew,
I just worked with VirtuosoŽ Analog Design Environment User Guide.
There I clicked on a link that readressed me to anasimhelp.pdf.
As in my environment help isn't properly installed, system couldn't find it.
But one thing is clear - anasimhelp.pdf is some other document.
Pavel
Pages: 1 2
