That's because you're still plotting v(out), not the value at 1Hz.
If you use Outputs->To Be Plotted, it's going to just plot the whole waveform - and consequently a family of curves if you do a parametric analysis.
Instead, use Outputs->Setup, and click on the Open button (next to the calculator expression). Build the expression as before - which will be something like:
db20(value(VF("/out") 1))
and then hit the Get Expression button in the Setup Outputs form. Give it a name, mark it to be plotted, and then Add.
Now when the simulation has finished, it will auto plot the expression versus the swept value.
Alternatively, just build the expression in the calculator after the simulation, and hit the plot icon in the calculator - this will do the same thing.
It would be wise to spend some time reading the manual. Hit the Help button in the corner of the ADE window, or run "cdsdoc" from the UNIX window, or take a look at <instdir>/doc/anasimhelp/anasimhelp.pdf . These are very basic usage questions, and reading the documentation is a good place to start.
