Aug 15th, 2024, 11:59am
How to compile a file Simulation.v ? (Read 15394 times)
ZaraCattle
Apr 16th, 2007, 4:11am
I created a simulated file that i typed code verilog into it(named Simulation.v)I use "$monitor" or "$Display" to print out monitor. But I don't know how to compile them to test my circuit...So how to compile them ?..Everybodd can help me ? Thanks very much...
Re: How to compile a file Simulation.v ?
Reply #1 - Apr 16th, 2007, 5:34am
Well, that rather depends on which tools you're using!
If you're using Cadence's Verilog simulator, you'd type ncverilog Simulation.v if you want to keep the command line interface as simple as possible.
Or you could always read the documentation for the tools you're using. That's probably more efficient than asking a vague question to a large forum and expecting them to guess what tools you're using and what you're trying to do.
ZaraCattle
Reply #2 - Apr 16th, 2007, 10:29am
Ah,sorry to everybody..I'm using Quartus II, a software of altera...And I don't know how to compile file Simulation.v..So Can you show to me some tools that I can simulate my file....Thanks very much....
Reply #3 - Apr 17th, 2007, 6:56am
Have you tried the user's guide for Quartus II?  Personally, I've never used it, and I don't even know if it's a Verilog simulator!  Can you run it from the command line?
Are you trying to add the Simulation.v file to a circuit that you're already able to simulate?  Or run the .v file as its own simulation?
ZaraCattle
Reply #4 - Apr 18th, 2007, 6:43am
I created a file Simulation.v like this:
module stimulus;
// Set up variables
reg [3:0] A, B;
reg C_IN;
wire [3:0] SUM;
wire C_OUT;
// Instantiate the 4-bit full adder. call it FA1_4
fulladd4 FA1_4(SUM, C_OUT, A, B, C_IN);
// Set up the monitoring for the signal values
initial
begin
  $monitor($time," A= %b, B=%b, C_IN= %b, --- C_OUT= %b, SUM= %b\n",
				  A, B, C_IN, C_OUT, SUM);
// Stimulate inputs
initial
begin
  A = 4'd0; B = 4'd0; C_IN = 1'b0;
  #5 A = 4'd3; B = 4'd4;
  #5 A = 4'd2; B = 4'd5;
  #5 A = 4'd9; B = 4'd9;
  #5 A = 4'd10; B = 4'd15;
  #5 A = 4'd10; B = 4'd5; C_IN = 1'b1;
I followed on the instructions of my book ....
And I don't know how to run this file that use "$monitor" function.....My book wrote that
The output of the simulation is shown below.
0 A= 0000, B=0000, C_IN= 0, --- C_OUT= 0, SUM= 0000
5 A= 0011, B=0100, C_IN= 0, --- C_OUT= 0, SUM= 0111
10 A= 0010, B=0101, C_IN= 0, --- C_OUT= 0, SUM= 0111
15 A= 1001, B=1001, C_IN= 0, --- C_OUT= 1, SUM= 0010
20 A= 1010, B=1111, C_IN= 0, --- C_OUT= 1, SUM= 1001
25 A= 1010, B=0101, C_IN= 1,, C_OUT= 1, SUM= 0000
Reply #5 - Apr 18th, 2007, 8:58am
ZaraCattle
Reply #6 - Apr 19th, 2007, 12:30pm
Ok..I knew that..But it only describes a result of wave file..I need the result that is console like my book.. ....
Reply #7 - Apr 20th, 2007, 5:58am
I ask again: Can you run Quartus II from the command line?  Or is it a graphical interface only?  Are you sure it's what you want? since the web site (as I was poking around) seemed to indicate it was for simulating FPGAs, and specifically Altera's products.
I have a vague recollection that Dolphin has a free demo version of SMASH (Google "dolphin smash demo"); maybe that will work better for you.
jbdavid
Reply #8 - Dec 18th, 2008, 7:23pm
or you could try Icarus.. its an open source verilog simulator..
or Cver
jbdavid
