Aug 15th, 2024, 2:21pm
Contour plots of Niose Figure (Read 2683 times)
SuperMentor
Apr 21st, 2007, 4:46pm
Can you tell me how I obtain the NF contour for LNA in the space of (Id and W) using the Cadence spectre as attached?
Thank you
James Bond
Re: Contour plots of Niose Figure
Reply #1 - Apr 22nd, 2007, 1:22am
I have never tried this before, but I suggest you try using W as a variable and sweep it in a range ,and you will get different current.
ACWWong
Oxford, UK
Reply #2 - Apr 26th, 2007, 2:57am
sweeping for fixed NF doesn;t sound quick to do in spectre. It looks like the plot you have is generated from some equations and ploted in something like matlab/mathcad etc.
anyway one (labourious) way to do it in cadence would be to sweep current for fixed W and tabluate NFmin (from an sp sim).
Then step W and do it again.
Then load the data into something like Excel or matlab to give the constant NF contours
