Oct 1st, 2024, 12:15am
LDO, ESR of the capacitor (Read 4343 times)
Faisal
Apr 23rd, 2007, 8:21am
I have a questions related to LDO.
ESR variation of capacitor with frequency: What value of the ESR (for the capacitor) should I consider in my simulation?  The ESR of the capacitor varies with frequency. At the moment, I take the value of ESR near resonance (from the capacitor data sheet).
Faisal
zhonghan
china
Re: LDO, ESR of the capacitor
Reply #1 - Apr 23rd, 2007, 8:57pm
I think temperature coefficient of ESR is more often concerned . For 1uf ceramic capacitor , typical ESR is 0.01ohm with good immunity to temperature. But for large ceramic capacitor , the variation due to temperatur become prominent.
amitsh
Reply #2 - Apr 23rd, 2007, 9:52pm
the typical esr values usually range from 50m ohms to 10 ohms for a standard 4.7uF cap, so depending on the type cap you are using, you should choose appropriate values for esr. for simulation also the esr values make the pole freq change. so chose the value from the cap datasheet and simulate ldo, such that it shouldnt effect your stability of ldo.
Faisal
Reply #3 - Apr 24th, 2007, 1:27am
Please see pg 9 of this attached document. ESR vs frequency curves are specified. Now ESR varies considerably with frequency. (Note that these curves are not specified till DC but rather the minimum frequency is 10 Hz)
Which frequency shall I consider for selecting ESR value and why?
Faisal
Reply #4 - Apr 24th, 2007, 2:41am
I attach another data-sheet of a ceramic capacitor.
Faisal
Reply #5 - Apr 26th, 2007, 1:11am
After modeling the ESR variation vs. frequency as described in the Ken Kundert's paper "Modeling Dielectric Absorption in Capacitors", I have come to conclusion that for LDO, only the ESR value near the resonance frequency is critical.
The Resistance value at low frequencies has no influence either on stability or transient behavior, probably because of high time constants.
I would like to know about the experience of ESR with other LDO designers on this forum
