May 18th, 2024, 3:03am
Synthesis of CML circuits (Read 2494 times)
krishnap
Apr 24th, 2007, 11:17pm
Is the synthesis of Current Mode Logic circuits possible?
Like the synthesis of normal digital circuits used in the
mixed signal circuits
Any idea regarding this?
Krishna
svenn
Does it have to be
legal?
Re: Synthesis of CML circuits
Reply #1 - Jun 21st, 2007, 12:24pm
I have seen some work done on synthesizing CML. Basically you need to characterize a 2-input NAND for, say Synopsys, and you can go ahead. Place and route has also been done and some skill code is written to handle the parallel routing. Given the static current nature of CML logic, you need to design your leaf-cells wisely. Most CML experts I have talked to frown upon such an approach.
Svenn
