Aug 17th, 2024, 11:16pm
Integer Boundary Spurs for Frac N Synthesizer (Read 770 times)
rf_ee
May 02nd, 2007, 3:20pm
What are the methods for reducing the integer boundary spurs in a Frac N synthesizer?
(Spurs occuring when the fractional value is quite low)
The loop bandwidth cannot be changed due to settling time requirements.
The synthesizer architecture can be modified.
It is preferred not to change the reference frequency.
Any information on this topic would be appreciated.
Thanks!
DaveB
Re: Integer Boundary Spurs for Frac N Synthesizer
Reply #1 - May 2nd, 2007, 5:29pm
Can you change the Sigma Delta modulator to add LSB dithering? You may not be able to do much about it.
Dave
hamen
How can I simulate jitter in hspice or spectre
Reply #2 - May 3rd, 2007, 11:23am
Dear
I am a master student in KULeuven. I used your method for modelling of
noise in pll as a jitter. I want to simulate the jitter in hspice or
spectre. In the other words, how can I simulate the jitter and see the
power density of noise in the output of the close loop pll using spectre
or hspice.
thanks in advance
Mohammad Masoumi
