May 18th, 2024, 10:46am
running Skill code when distributed Job completes (Read 2700 times)
Matt VD
May 07th, 2007, 1:31pm
I would like to run some Skill code after running a distributed job from within Cadence ADE.
So my question is: does anyone know how to run a function whenever another function runs?
Alternatively: how about running some Skill code after a given text output appears in the ICFB?
Re: running Skill code when distributed Job comple
Reply #1 - May 8th, 2007, 7:27am
There is no generic answer to this - each situation is different. It usually depends on whether there is a public trigger mechanism for registering a trigger at a particular point.
I suggest you contact Cadence support to ask these questions - it may well require enhancement to the tools.
