May 12th, 2024, 3:42am
Pulse source in Verilog-A(MS) (Read 3151 times)
nvs117
May 08th, 2007, 7:09am
Hi there,
What are the possibilities to model a source which gives a rectangular voltage (or position) pulse at a certain time point?
I have tried this here, but this is doesn't give the right result - it always produces large outputs (either below or greater zero).
BTW: Don't hesitate, this is a signal-flow approach! Wink
// position pulse
module pos_pulse (out_pos);
   parameter real startval = 10.0;
   parameter real endval = 0.0;
   parameter real period = 100.0;
   parameter real starttime = 1.0;
   parameter real endtime = 15.0;
   output out_pos;
   position out_pos;
   analog begin
       @(initial_step) begin
     Pos(out_pos) <+ slew(startval, 1.0e-9, 1.0e-9); // also tried "transition" here
     @(timer(endtime)) begin
     Pos(out_pos) <+ slew(endval, 1.0e-9, 1.0e-9); // also tried "transition" here
Any ideas?
Chris
Re: Pulse source in Verilog-A(MS)
Reply #1 - May 8th, 2007, 12:06pm
nvs117 wrote on May 8th, 2007, 7:09am:
I don't think this is legal syntax ...  you shouldn't have <+ nor slew inside an event.  Instead, you should have a real value that gets set in the events, and the contribution should be performed always:
real outval;
@(initial_step) outval = startval;
@(timer(endtime)) outval = endval;
Pos(out_pos) <+ transition(outval, 1n, 1n);
nvs117
Reply #2 - May 9th, 2007, 3:59am
Hi Geoff,
This works fine.
Thanks from a VAMS newbie.
