Sep 29th, 2024, 10:18pm
A question on the step response (Read 3056 times)
dandelion
May 08th, 2007, 7:14pm
I know I can do the open loop analysis to investigate the stability. But in some times, we prefer to do the transient step response to see if it is stable.
I want to know, in doing the step response analysis, how should I select the rise up time and especially the amplitude of the step pulse?
Pls. give me some advice.
Dandelion
Re: A question on the step response
Reply #1 - May 9th, 2007, 7:00am
Dandelion,
  Usually you use a fast edge compared to the DUT, for example,
1ns for a 10MHz op-amp. The pulse levels need to be small enough
not to induce large signal behavior, i.e., slew rate limiting, and large
enough to produce numerically accurate results. Usually +/- 10mV at
the output is good enough.
  Could you clarify why you want to use transient analysis for stability
analysis? The only times I have used transient analysis for stability
analysis is when there are conditions that small signal will not identify,
for example, there are large signal phenomena that may effect the
stability. The issue in that case is that these are large signal simulations
and the general guidelines for small signal stability characterization do
not apply.
dandelion
Reply #2 - May 9th, 2007, 7:51pm
sheldon wrote on May 9th, 2007, 7:00am:
Dandelion,
not apply.
Thanks for your reply, Sheldon. It is helpful to me.
Yes, we will do the transient analysis for the stability when there are large signal behavior.
Another reson we prefer to do it is to hope to avoid the loading effect when we are not sure how to break the loop properly.
Dandelion
wave3x
Shang Hai, China.
Reply #3 - Jun 2nd, 2007, 6:34am
You can use "pss+pstb" for your large signal stability analysis, if you have spectreRF.
of course, transient is alway the robustest method to check stability.
