sheldon wrote on May 9th, 2007, 7:00am:Dandelion,
Usually you use a fast edge compared to the DUT, for example,
1ns for a 10MHz op-amp. The pulse levels need to be small enough
not to induce large signal behavior, i.e., slew rate limiting, and large
enough to produce numerically accurate results. Usually +/- 10mV at
the output is good enough.
Could you clarify why you want to use transient analysis for stability
analysis? The only times I have used transient analysis for stability
analysis is when there are conditions that small signal will not identify,
for example, there are large signal phenomena that may effect the
stability. The issue in that case is that these are large signal simulations
and the general guidelines for small signal stability characterization do
not apply.
Thanks for your reply, Sheldon. It is helpful to me.
Yes, we will do the transient analysis for the stability when there are large signal behavior.
Another reson we prefer to do it is to hope to avoid the loading effect when we are not sure how to break the loop properly.
Dandelion
