May 4th, 2024, 10:53am
useful website for vlsi chip designers (Read 4544 times)
vlsichipdesigner
May 11th, 2007, 1:03am
A technical website for vlsi chip designers with lots of useful information concepts/design flows/design practices/tips/lessons learnt related to vlsi chip design.
http://www.vlsichipdesign.com
Re: useful website for vlsi chip designers
Reply #1 - May 12th, 2007, 2:53am
There's a problem with most of the pages on your website. Because the various pages do not have a .html suffix, they are being received as text/plain - and so compliant browsers such as firefox are showing the pages as text, rather than HTML.
You've probably just checked it using Internet Explorer - which seems to interpret plain text that happens to have a <html> tag in it as being HTML, but that's a bit of a wild assumption on its part.
To see what I mean, here's the transcript of a couple of "wget" sessions from Linux. The first one shows the front page of your site (which is in index.html):
> wget http://www.vlsichipdesign.com
--10:46:47--  http://www.vlsichipdesign.com/
	     => `index.html'
Resolving www.vlsichipdesign.com... 209.67.215.10
Connecting to www.vlsichipdesign.com|209.67.215.10|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 12,760 (12K) [text/html]
100%[====================================>] 12,760	  --.--K/s
10:46:47 (269.10 KB/s) - `index.html' saved [12760/12760]
And this one is from one of the sub-pages. As you can see, this is sent as [text/plain] rather than [text/html]. Note, the file doesn't necessarily need to have a .html suffix (this is dependent on the settings on your web server), but the key thing is that it is sent as text/html - and usually the easiest way to do that is to give the file a .html suffix:
> wget http://www.vlsichipdesign.com/analogy_vlsi_building
--10:47:17--  http://www.vlsichipdesign.com/analogy_vlsi_building
	     => `analogy_vlsi_building'
Length: 12,994 (13K) [text/plain]
100%[====================================>] 12,994	  34.77K/s
10:47:18 (34.66 KB/s) - `analogy_vlsi_building' saved [12994/12994]
Unless your site works in browsers other than IE, you're going to severely limit your audience...
xn47
Japan
Reply #2 - Jun 12th, 2007, 6:43pm
Explanation: An IP address for the website you requested could not be found. As a result, it was not possible to access the site.
'm using IE7 and still can't access the site..
any helpful site for OPTICAL VLSI designer??
