Aug 17th, 2024, 7:24pm
why need low pass filter in image reject mixer (Read 2200 times)
sapphire
May 12th, 2007, 11:20pm
seems like the sum frequency components would also be rejected by the architecture.
carlgrace
Berkeley, CA
Re: why need low pass filter in image reject mixer
Reply #1 - Jun 1st, 2007, 5:29am
The image's sum would be rejected but there would be a sum component in the output.  Also, the summing circuit would have to be perfectly balanced for there not to be an issue of intermod.
Reply #2 - Jun 5th, 2007, 11:29am
agree with the above - In an ideal math only world, things can cancel perfectly. In a real world method, there will always be some junk there that was not cancelled out
