Sep 12th, 2025, 9:01pm
EE Times commentary: analog layout automation (Read 12381 times)
mg777
May 20th, 2007, 7:28pm
EDA veteran Jim Solomon on analog layout automation:
http://www.eetimes.com/news/design/showArticle.jhtml?articleID=199601718
didac
There's a million
ways to see the
things in life
manresa,spain
Re: EE Times commentary: analog layout automation
Reply #1 - May 20th, 2007, 11:54pm
Good article, it explains  very clear which are the main problems of analog layout and how must be the solution. The only sad thing for me is that  I must hurry to get the Phd or at the lab I will be obsolete as "layout man"...
krishnap
Reply #2 - May 23rd, 2007, 7:25am
Articel gives good insight on the needs for analog layout automation.
Currently few options like autorouter , where precesion is not important
and  pcells for bigger modules etc are giving some speed.
weber8722
Reply #3 - Oct 29th, 2012, 7:16am
Hi, reading this article from 5/17/2007 now - 2012 - I think not much has changed at all!!! Sad
For most non-trivial circuits, like having 40 transistors most autoplacer fail, although a good designer can find a solution quickly. The constraint concept ends up with adding more and more constraints, till you have no overview anymore or run into over-constraintment or tool problems!
Take a look at "Deterministic Analog Circuit Placement using Hierarchically Bounded Enumeration and Enhanced Shape Functions", 2010. This paper describes an advanced placer, but the created layout would NEVER survice a real-world design review  :'(.
It seems that our PhD workers like to create new and more algorithms, but not even have criteria or benchmark to decide what a good layout is!
Bye Stephan
Dan Clement
Salt Lake City, Utah, USA
Reply #4 - Oct 31st, 2012, 8:09pm
Check with the analog rails guys...
