Aug 16th, 2024, 1:21pm
How to measure NMF(Noise Modulating Function) (Read 137 times)
JC
May 22nd, 2007, 12:37pm
Recently I am trying to simulate the ISF(Impulse Sensitity Function) for my VCO using Spectre. I have to measure the NMF for transistor's drain thermal noise. I have two methods as shown in the following figure.
The second method is approximately derived from the frist one, because I don't konw clearly how to measure the drain noise current correctly.
My questions: 1. How to measure drain noise current  using Spectre?
                    2. Is there other methods to  measure NMF?
Re: How to measure NMF(Noise Modulating Function)
Reply #1 - May 24th, 2007, 5:22am
JC,
 It may not help you directly, but there is another figures of Oscillator
merit the perturbation projection vector, PPV. For more information, see
Frank Wiedmann's comment in the following e-mail,
http://www.designers-guide.org/Forum/YaBB.pl?num=1179739160/1#1
or the following reference,
<<reference to chapter 2 of Hegazi, Rael, and Abidi (http://www.designers-guide.org/Books/dg-osc/index.html) was deleted by forum administrator>>
  The good news is that SpectreRF will directly output the PPV for a VCO. To save
the PPV, in the PSS window:
select "Oscillator" then "options", in the options window select "save osc ppv".
You can use the Results Browser to access the PPV.
« Last Edit: May 24th, 2007, 8:07am by Forum Administrator »
JC
Reply #2 - May 25th, 2007, 6:41am
Sheldon,
 Thanks for your help.
 Unfortunately the Cadence version IC5104 doesn't contail this option in PSS simulation. So I cann't see anything about PPV. Is the PPV contained in this version (IC5104)?
  Another quesion is: If I have to use the second method described above, How to get threshold voltage? Can I just treat threshold voltage as a constant value? Dose this impact the accuracy a lot?
JC
