Aug 17th, 2024, 7:23pm
Sources of Jitter (Read 2311 times)
savithru
Sources of Jitter
May 24th, 2007, 3:20am
hi
I am working on optimizing the PLL For better jitterperformance.
Now the earliar simulated jitter values are well with in the boundary. How ever the measured (post silicon) jitter values are outside the required boundary.
Can any of you plsease tell me how I can tackle the "Schematic" to reduce the Jitter.
i am starting with VCO ( Current Starved).
Pls tell what might have went wrong here.
Also kindly tell me the procedure to measuer the periodic Jitter and Long term Jitter.
Thanks & Regards
SavithRu
View Profile savithru savithru   IP Logged
adesign
Re: Sources of Jitter
Reply #1 - May 28th, 2007, 2:30am
Power supply noise contribute in remarkable jitter component.
See the PSRR of V-to-I converter in VCO.
adesign
Reply #2 - Jun 8th, 2007, 4:46am
For jitter measurement on Silicon, you can use wavecrest jitter measuring instruments.
