Aug 17th, 2024, 9:14pm
channel selection (Read 4349 times)
aaron_do
channel selection
May 28th, 2007, 2:35am
I was wondering, how does a transceiver know which channel to use? Does it just continuously sweep its channels until it picks up a signal? where would i find information like this?
thanks,
Aaron
didac
There's a million
ways to see the
things in life
manresa,spain
Re: channel selection
Reply #1 - May 28th, 2007, 2:46am
Hi Aaron,
It depends on the standard. On the GSM system after the access to the base station the mobile phone are assigned to a frequency and a Time Slot for receiving and transmitting, on the other hand in Bluetooth the master device rules the system with his clock(that its previously known by the slave devices when they connect to the piconet) that controls the frequency-hopping scheme, so the slave knows at which frequency it must "hear" in each instant and only has to read the header of the frame to identify if the frame is for it or is for another device. So the best thing will be to see the radio specification for your standard because each system is a world apart.
Good luck,
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #2 - Jun 2nd, 2007, 8:04am
Hi again,
I think that you can take a look at chapter 4 of RF Microelectronics of Prof.Razavi, it explains quite well this kind of things and includes a few examples(not in depth).
PS:sorry for not giving you a reference in the previous post.
aaron_do
Reply #3 - Jun 2nd, 2007, 5:50pm
thanks, i know which book you mean
Aaron
Reply #4 - Jun 5th, 2007, 11:26am
Aaron:
2 hats:
IC Designer
Communication System Designer
Pick one, right? If you take your ICD hat off and put your CSD hat on, they get into the whole world of protocalls and methods.
Ever hear of things (in CSD parlance) called the PHY and MAC layers?  Most of the time, ICD folks are all about the PHY layer. Physical rendering, this frequency, linearity IRN, etc etc.
Depending on the system, there are many different ways that this can happen, and it is usually defined at the MAC layer.
Jerry
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #5 - Jun 5th, 2007, 12:18pm
Hi Jerry,
I must say that I'm a Telecommunications Engineer, so most of my education is based in protocols,math,signal processing,signal theory and this kind of things. But one of the possible specialitzations offered at my university is microelectronics and at my group(RF guys) all are from Telecommunications, no one is from Electrical and Electronic Engineering(VLSI guys and Power guys are more from this branches).
I disagree with your point of view that you must only focus on IC design or protocol(PHY,MAC and so on), I think that nowadays an engineer working in communications systems must have a mixed background and not only has to know how to read a specification given by the System Engineer. Just my opinion altough,
Didac
