Aug 16th, 2024, 11:25am
Noise analysis (Read 3819 times)
aaron_do
Noise analysis
May 29th, 2007, 1:42am
just a quick question. If i run a noise analysis, does the simlated output noise have any dependence on input frequency. i.e. i'm not concerned with input referred noise, but the input frequency is not equal to the output frequency. Also it's not a mixer so i'm not sure if i can use pnoise analysis.
thanks in advance,
Aaron
ACWWong
Oxford, UK
Re: Noise analysis
Reply #1 - May 29th, 2007, 4:29am
noise analysis is a frequency domain simulation on a linearised (time-invariant) operating point. At any particular small signal frequency it'll compute the output noise at that frequency, with all the components equations using the same value of frequency in their equations and using the computed linear transferfunctions/gains to the the output.
pnoise is useful if you have frequency translation effects in your circuit, such as mixing or sampling etc.
try ken's books and papers on the subject...
perhaps if you elborate a bit more on what exactly you are trying to simulate ?
aaron_do
Re: Noise analysis
Reply #2 - May 29th, 2007, 5:57pm
i'm trying to simulate a peak detector. The peak detector is followed by a RC low pass filter. My concern is, suppose the bandwidth of my signal before peak detection is 1 MHz: does all the noise in the 1 MHz  band get peak detected and converted to DC? Is it possible to simulate this? i.e. if the noise gets clipped it technically will result in a DC component.
thanks,
Aaron
ACWWong
Oxford, UK
Re: Noise analysis
Reply #3 - May 30th, 2007, 2:28am
ok, i think no need for pnoise or anything here.... you can use noise analysis to give you the output noise spectrum.... from this you can get an idea of the amplitude of noise at any one frequency which will be additive to your signal... i think you'll find the noise levels should not be a significant percentage of the signal amplitude you are expecting....
If noise levels are going to problematic (and you can improve your design so that noise becomes insignficant), then a simulation solution would be to simulate using transient noise analysis.
cheers
aw
aaron_do
Re: Noise analysis
Reply #4 - Jun 2nd, 2007, 5:54pm
I ran the noise analysis and you are right, there wasn't much noise. I was worried that with peak detection, the noise in the signal bandwidth would be converted to a DC component...do you know why that didn't happen?
thanks
Aaron
