Sep 29th, 2024, 10:20pm
crystal oscillator simulation in cadence (Read 5148 times)
rajeee1000
Bangalore
Jun 06th, 2007, 3:34am
Dear,
I am designing a 32 KHz crystal oscillator in cadence. I see the problem of the oscillation amplitude depending significantly on the initial condition (inductor current). Is there a way to faithfully estimate the oscillation amplitude or rather to choose the correct initial condition?
Thanks in advance
Rajesh
PS: I don't have access to any harmonic balance simulator
Re: crystal oscillator simulation in cadence
Reply #1 - Jun 8th, 2007, 1:59am
I am not aware that the amplitude depends on the initial condition, like the initial current in inductor. However, the amplitude depends on the integration method strongly. Generally, I get smaller amplitude when I choose method = gear than that when I choose method = trap.
However, I have not compared the simulation result with the test results.
Best regards,
Yawei
jeffyan
Reply #2 - Jun 14th, 2007, 6:06pm
rajeee1000 wrote on Jun 6th, 2007, 3:34am:
Dear,
Thanks in advance
Rajesh
hi
yes, there are some methods to calculate the amplitude theoretically in papers by qiuting huang, and vittoz.
vivkr
Reply #3 - Jun 15th, 2007, 7:18am
Hi Yawei,
That's probably because gear maps some poles on the jw axis to the LHP => unstable systems may simulate
as stable if gear is set. For these cases, trap is better as it provides the best mapping.
However, with gear, you can also achieve the same results with tighter tolerances (atleast that's what the manuals say).
I would say that your measurements should probably match the trap simulation.
Hi Rajesh,
There are several papers by Vittoz and also by RG Meyer (of Gray & Meyer fame), all from the 70s or 80s from IEEE
JSSC. Try searching for crystal oscillators in the search section there
Vivek
ywguo wrote on Jun 8th, 2007, 1:59am:
Best regards,
Yawei
