smarty
Hi all, I have a basic question relating to Data dependant jitter. Its a combination of ISI, DCD and other effects. I see that to remove the ISI effect and evaluate DCD, provide a 101010.. pattern. Is it the correct method by which the DCD can be calculated.
Also Can anybody suggest, how can the DCD measured in terms of time. What I know till now is DCD is the variation of duty cycle from the normal value and can be measured in %(50% ideal) ( pls. correct me if my understanding is wrong). So if I need to know the DCD in terms of time, how can that be done?.
Is there any paper, which gives me some good ideas regading the various jitter and its effects?.
One more in the same context. How can we evaluate various jitter from the Eye diagram?. Can anybody suggest any paper relating to this.
Thanks and Regards, SBR
