Aug 16th, 2024, 1:19am
help on pss and pnoise analysis to PFD and CP (Read 4543 times)
jeffyan
Jun 06th, 2007, 10:27pm
HI ALL,
how can i do the pss and pnoise to PFD and cp.
because when the output of cp can not get into a steady state that i can run pss.
someone told me tie a fixed voltage source to the output of cp, and run pss and pnoise, and at last, measure its noise current.
is it a right way to get the noise?
thanks,
Re: help on pss and pnoise analysis to PFD and CP
Reply #1 - Jun 6th, 2007, 10:46pm
jeffyan
Reply #2 - Jun 8th, 2007, 12:51am
Ken Kundert wrote on Jun 6th, 2007, 10:46pm:
hi ken,
the paper said:
"In this case, a representative signal would be one that produced periodic switching at the output. This
is necessary to capture the noise present during the switching process."
sorry, i don't  understand very well on above, you means, i can inject two un-matched clock signals purposely, to compensate the mismatch of the charge pump currents. in this case, the output of cp can be produced periodic switching,right?
thanks.
Reply #3 - Jun 8th, 2007, 11:46pm
Yes, but if the output is a current, you cannot dump it into a capacitor. The result will not reach steady-state until the output clips. Instead, dump it into a current probe as your initial post suggested.
jeffyan
Reply #4 - Jun 14th, 2007, 6:21am
hi Ken,
thanks,
you mean we can tie a constant voltage source, saying 1volts to the output of cp, and inject a clock both to the two inputs of PFD, then do pss and pnoise analysis to probe the current noise of the voltage source. is it right?
thanks again.
Reply #5 - Jun 14th, 2007, 9:34am
yes
