Sep 17th, 2024, 4:25pm
common mode noise. (Read 2693 times)
smarty
common mode noise.
Jun 07th, 2007, 10:16am
 I am working on high speed receiver. I am  simulating the differential receiver for performance.
I would like to test the receiver by injecting  AC common mode noise of 150mv(peak) on the inputs.
Could anybody suggest as to how I can make this setup in my simulation to inject this noise?.
Thanks and Regards,
SBR
View Profile smarty smarty   IP Logged
Re: common mode noise.
Reply #1 - Jun 7th, 2007, 3:52pm
Smarty,
  If you have access to ADE, then why don't you try using the
ideal_balun. It allows you to independently input a common-
mode signal and differential-mode signal and generate
differential outputs. The implementation is discussed in Ken's
book, "The Designer's Guide to SPICE and Spectre".
smarty
Reply #2 - Jun 10th, 2007, 7:59pm
Hi Sheldon,
 Thanks for your response.
SBR
