Aug 16th, 2024, 5:13am
Question on PXF & Transient simulation for mixer (Read 2725 times)
James Bond
Jun 08th, 2007, 12:20pm
Hi, all
I have been stuck by this problem for several weeks, if someone knows this, please give me some suggestion, any commment would be appreciated.
I designed a passive mixer, first I used transient to find conversion gain (Vif/Vrf), it's about the 0.9 times , almost
-1dB; Then I used pss+pxf simulation to verify the conversion gain, I am pretty sure I set the pxf and pss form correctly, but the simulation result shows that the conversion gain is about 20dB, it conflicts with the transient simulation. Could you tell me what will cause this problem?
Thank you very much.
Best Regards
Bond
didac
There's a million
ways to see the
things in life
manresa,spain
Re: Question on PXF & Transient simulation for mix
Reply #1 - Jun 9th, 2007, 2:39am
Take a look at:http://www.cadence.com/community/virtuoso/resources/SpectreRF_Mixer533AN.pdf to take a look at the pps+pxf configuration just to check it. Also I doubt that doing a Vif/Vrf give you the correct gain in a mixer unless you have filtered the output due to the harmonic components,leakage and other effects.
Good luck,
James Bond
Reply #2 - Jun 9th, 2007, 7:58am
Thank you for your suggestion. I have checked that doc, and my setting is correct. BTW, the Rf freq is 1.9G, the Lo freq is 1.91G.
I also simulate the core passive mixer individually, the conversion gain is about the -4dB with a capacitive load about 300fF, I check this conversion gain with both transient simulation & pss+pxf, they are coincident; Then I add some other circuit which can achieve extra gain before the passive mixer, then this time, the transient simulation & pss+pxf are not coincident. If the filter worked before, it will also work this time.  And I think that the transient simulation will also consider the parasitic filter effect.
