Aug 18th, 2024, 11:26pm
overall NF (Read 5355 times)
aaron_do
overall NF
Jun 12th, 2007, 11:44pm
I am designing a low IF receiver, and i'm interested in finding the overall NF. I found that the spot NF is around 16 dB at 2 MHz, but if i integrate the total output noise from 10 kHz to 100 MHz, the NF is around 20.5 dB (although i think i can improve this somewhat). My system BW is only 1 MHz so is it necessary to integrate the noise over all frequency? I am using FSK with a simple demodulator at the output - will an ADC be better?
thanks,
Aaron
ACWWong
Oxford, UK
Re: overall NF
Reply #1 - Jun 13th, 2007, 2:44am
you just need to consider the system BW (your channel BW).
didac
There's a million
ways to see the
things in life
manresa,spain
Re: overall NF
Reply #2 - Jun 16th, 2007, 12:53am
Usually this is forgiven(and usually I didn't make use of it also) but the noise bandwidth is usually bigger that the nominal filter bandwidth(channel filter bandwidth at -3dB), technically you should computer the equivalent noise bandwidth of the filter(BN) and integrate the noise over this bandwidth(that give you an equivalent rectangular filter) but usually if the filter is sharp is less than 1.05-1.1 time your bandwidth.
aaron_do
Re: overall NF
Reply #3 - Jun 16th, 2007, 2:41am
I have a third order fitler, and i integrated the output noise of the system, and it was signifantly higher for all frequencies than just the filter bandwidth...
Aaron
didac
There's a million
ways to see the
things in life
manresa,spain
Re: overall NF
Reply #4 - Jun 16th, 2007, 4:00am
Hi Aaron,
Equivalent noise bandwidth must be calculated via integration of the transfer function of the filter(basically you found the equivalent rectangular shape that contains the area of the filter). Depending of the shape of your filter you will see more or less noise. As I said usually is a good approximation to integer over your -3dB bandwidth.
aaron_do
Re: overall NF
Reply #5 - Jun 16th, 2007, 9:34am
HI didac,
that doesn't seem to be what ACWWong was saying...he said to only consider the system BW. I originally thought I should integrate the output noise over all frequencies but now i'm not so sure......
Aaron
didac
There's a million
ways to see the
things in life
manresa,spain
Re: overall NF
Reply #6 - Jun 16th, 2007, 9:49am
Hi Aaron,
I suppose that ACWWong said that you should just integrate over your channel bandwidth. I think I only mess up things with a technical detail about the definition of noise bandwidth,let me see if I found a reference for you, but I think if  you integer over your channel bandwidth it's a good estimation of the noise you will be fighting.
PS:sorry if this detail caused you doubts,I will search a reference and try to post it but my undergraduate courses were all in Catalan or Spanish so I must dig a little bit to find a good reference.
didac
There's a million
ways to see the
things in life
manresa,spain
Re: overall NF
Reply #7 - Jun 21st, 2007, 12:09am
Hi Aaron,
Sorry for the delay in promised references, I've been performing measurements and I didn't have many free time. I've found two references in English that maybe will be useful:
1)"Design of CMOS RF Integrated Circuits" of Thomas.H Lee,Chapter 11,pages 334-337 explains and derives the equivalent Noise Bandwidth.
2)"Design of Analog CMOS Integrated Circuits",of Behzad Razavi,Chapter 7,page 239, says very straightforward the definition.
PS:As was talked before and ACWWong said I think that integrating over the channel BW it's good. The references are only if you are a curious about this definition.
Good luck with your design.
aaron_do
Re: overall NF
Reply #8 - Jun 21st, 2007, 8:57am
thanks for the help. I have the books so i'll check out the definition
Aaron
