Aug 3rd, 2024, 1:18am
Class AB output stage analysis (Read 5984 times)
adesign
Jun 14th, 2007, 1:12am
Dear all,
Please have a look at the attached "Class-AB output stage" circuit.
In this circuit,
(W/L)4=(W/L)9,
(W/L)3=(W/L)8
How do we ensure that current through M6 is equally divided between M3 and M4?
Also why
v2=v3,
v1=v4???
Please comment.
monte78
Re: Class AB output stage analysis
Reply #1 - Jun 14th, 2007, 1:22am
Hi!
I had similar questions short time ago, take a look to the following presentation (slide 15 up to the end):
http://amesp02.tamu.edu/~sanchez/607%20Lect%204%20Line%20Driver%20Design.pdf
The current will divide into two eaqual parts if the gm of the NMOS and PMOS transistors is equal.
However any other comment would be useful also for me.
Bye,
Monte
yvkrishna
Reply #2 - Apr 12th, 2010, 10:48am
hi guys,
i too have the same doubt. how to bias such that equal currents flow through M3,M4 ?
and how will having same 'gm do that? please elaborate
yvkrishna
Reply #3 - Apr 15th, 2010, 12:10am
gm of M3, M4 will not match. Not without some intelligent control or feedback to make it happen.
Not a good circuit architecture IMHO
yvkrishna
Reply #4 - Oct 5th, 2010, 4:56am
hi all,
does any one have some more understanding of this issue in biasing class AB structure?
especially how can we ensure that currents divide equally (M3,M4)with process variations ?
many thanks for the replies.
-yvkrishna
sli103105
Reply #5 - Oct 7th, 2010, 8:53am
IMHO, it's easier to put this into some Amplifier in feedback loop.
As it's already been pointed out, there're 2 TL loops
1) M9,10,4,2
2) M7,8,3,1
M6 is the bias current source and Vin will be adjusted by
the feedback loop such that current through M1 and M2
will be equal so that Vout stays around mid-rail. When that
happens, current through M3,4 will be roughly equal as well,
i.e., both equal to Ib roughly.
Lex
Eindhoven, Holland
Reply #6 - Oct 8th, 2010, 3:49am
I wonder how accurate this will be, with regard to drain source modulation.
