Sep 17th, 2024, 4:22pm
Relationship between phase noise  and output (Read 2843 times)
analog2000
Jun 15th, 2007, 9:53am
Would anyone please clarify the difference between the phase noise or jitter calcualted by Spectre RF (pnoise) and the output noise summary (in volts) also calcuated by the pnoise analysis ?
thanks a million
analog2000
didac
There's a million
ways to see the
things in life
manresa,spain
Re: Relationship between phase noise  and out
Reply #1 - Jun 15th, 2007, 1:23pm
Hi analog2000,
You are mixing two different concepts, phase noise and jitter are effects related to innacuracies of frequency in oscillators(jitter for digital circuits, phase noise in analog oscillators usually). Output noise(in V/sqrt(Hz) or V^2/Hz) is the measurement of thermal,flicker,shot,popcorn noise whetever applies in your case. In other words the first relates more to synchronization(in jitter case for digital systems) or undesired mixing(for rf front-end for phase noise,caused by the fact that you didn't have a true dirac delta in an oscillator) and output noise relates to the sensitivity of the system(which also causes that engineers have work, if noise didn't exist i communications systems will be more easy to design).
Hope it helps this explanation
« Last Edit: Jun 16th, 2007, 6:48am by didac »
analog2000
Re: Relationship between phase noise  and output
Reply #2 - Jun 17th, 2007, 12:58pm
Thanks didac for your response.
In Spectre RF you can simulate both phase noise/jitter and output noise using the print summary statements. This is if you do a pnoise simulation. I am just trying to correlate the results of both results i.e. print summary output which allows one to integrate the noise in a given bandwidth and phase noise which allows one to simulate jitter also in a certain bandwidth
thanks
analog2000
didac
There's a million
ways to see the
things in life
manresa,spain
Reply #3 - Jun 17th, 2007, 1:01pm
I usually use the GUI of spectreRF,plot the waveform and open the calculator, with the calculator you can select the waveform and use the integration function(integ if I don't remember bad,I don't have Cadence opened right now)
