didac
There's a million ways to see the things in life
manresa,spain
Hi analog2000, You are mixing two different concepts, phase noise and jitter are effects related to innacuracies of frequency in oscillators(jitter for digital circuits, phase noise in analog oscillators usually). Output noise(in V/sqrt(Hz) or V^2/Hz) is the measurement of thermal,flicker,shot,popcorn noise whetever applies in your case. In other words the first relates more to synchronization(in jitter case for digital systems) or undesired mixing(for rf front-end for phase noise,caused by the fact that you didn't have a true dirac delta in an oscillator) and output noise relates to the sensitivity of the system(which also causes that engineers have work, if noise didn't exist i communications systems will be more easy to design). Hope it helps this explanation
