May 4th, 2024, 3:40pm
Cadence hangs when dismissing properties dialog (Read 1725 times)
stephen
Jun 15th, 2007, 12:33pm
I am a problem with the linux version of cadence.
After I am done viewing or editing the properties of a component in Virtuoso schematic editor, I will close the properties dialog. However, cadence will hang for about 20 seconds before becoming reponsive again.
The same problem does not happen when I launch the solaris version of cadence.
My cadence version is 5.10.41_USR3.27.30.
I am running cadence remotely via Exceed from my desktop PC (running windows XP). It shouldn't be problem of Exceed since the same problem happens when I use FreeXer to access the remote server.
Any fix for this issue? This gets very annoying when I need do a lot of changes to the schematic.
Thanks a lot.
