weelo
Thanks for the info.
As far as I can tell, spectre (mmsim61), ultrasim, and assura 316 all have 64bit versions of the tools, and these are the ones I care about the most.
Typical sims I might run with spectre would be something like a simple block or behavioral model which I do a transient 2ms run on. It takes about 2 min on a P4 3.8GHz machine. The sim is scripted to run between 50 and 100 cases. For something like this, it's not a terribly big deal if 32b-spectre is slower than 64-b spectre.
Circuit inventory: nodes 116 equations 196 ahdl simulator 1 va_ideal_clamp 3 va_ideal_clamp2 3 va_sr_latch 3 va_comparator 3 capacitor 15 cccs 6 diode 15 inductor 3 mos1 12 quantity 9 relay 9 resistor 27 vccs 6 vcvs 6 vsource 47
However, for mid-level or top-level simulations and extracted sims, using spectreVerilog, the netlist looks like: Circuit inventory: nodes 4318 equations 13684 a2d 36 bsim3v3 3999 capacitor 2355 d2a 53 diode 928 inductor 2 isource 2 quantity 9 resistor 1911 vbic 28 vsource 650
Something like this takes between 10hrs and >40hrs for a 1ms transient run on the same machine. The actual time depends on various modes of the circuit and its dynamic behavior during certain intervals of the simulation.
I am looking for any possible way to shorten these 40hr runs to something more reasonable. The machine is not in danger of running out of memory for these sims, so if 32b spectre could be any faster, I'd retool my fast box for 32b linux instead.
