aamar
You have the full permition naturally.
But what I meant here is not the power dissipation in the form of currents flowing through the transistors from supply to ground or from output to ground or vise versa, what I meant here is an energy stored on the capacitance (unintentionally) because normally I would like not to have any capacitances at all, so storing this energy on the capacitance is even for me a dissipated energy.
Hope that you got what I mean. Normally if there is no capacitances the delays should be all zeros, this means that whole energy is directly subjected to the gate to turn it, as if you are pushing a box directly without inerfaces, or pushing it with a spring in between, so you have to give some energy to the spring to contract it before acting on the box, this is in this case an energy stored in the spring which will return back anywhere, but for you it is dissipated energy, which you would like to save, and it causes you only delay (but it can be used as memory too if it is required).
Best regards,
aamar
