Sep 29th, 2024, 6:24pm
Feedback loop simulation and Switched cap (Read 3946 times)
joeb
Jul 03rd, 2007, 9:44am
How you check the stability of your amplifier in a switched cap configuration?
In case of gain boosting op amp, how you check the stability of ur overall amplifier.
How to use stb option in cadence? What stb does exactly?
Thanks for your answers.
topquark
Thames Valley, UK
Re: Feedback loop simulation and Switched cap
Reply #1 - Jul 11th, 2007, 7:38am
Hope you already searched for some links on the topic.
here's one:
http://www.designers-guide.org/Forum/YaBB.pl?num=1156429424/0#0
A quicker 'n simpler way (which may not work always) to get a gain/phase margin plot is to break open the loop, put ideal volatge sources at appropriate nodes 'n do ac analysis sweeing freq.
joeb
Reply #2 - Jul 12th, 2007, 12:50am
Hi
Thanks for ur answer. I think that is the best one.
Reply #3 - Jul 12th, 2007, 11:04am
Never break the loop. Use stb analysis instead. It computes the loop gain, and then extracts the phase and gain margins from that. If your amplifier has switched-capacitor common-mode feedback, you will need to use pstb analysis.
HdrChopper
Reply #4 - Jul 14th, 2007, 9:31pm
hi,
To check for the op-amp stability I would replace the switched caps by the equivalent resistor value and IŽd analyze the stability by computing gain/phase margin (easy and fast).  You can either open the loop appropriately (be careful you are able to recreate the same DC loading conditions at the node you break the loop when you run your AC analysis!) or could run your stb analysis (which I do not like much since you never know exactly where the bias point is calculated).
Keep it simple
