Jul 21st, 2024, 6:27am
A question on the transient analysis of HSPICE (Read 2887 times)
dandelion
Jul 11th, 2007, 10:23pm
I have a question on the HSPICE tramsient analysis. My circyuit is a triangular wave gennerator. I found the waveform is good before 1ms. But when after the 1ms, the waveform becomes not so smooth. I checked the simulator and i found the time step becomes loose after 1ms. Key point here is the block is always in steady state from the begining.
I tried the Smartspice, it is OK and no have this phenominon.
Anyone pls. tell me why?
Thank s a lot!
Re: A question on the transient analysis of HSPICE
Reply #1 - Jul 15th, 2007, 8:04pm
What is the period of your triangular wave generator?
What is the step size of your .tran command? Do you set .option method = gear instead of the default method=trag? What does the steady state mean?
Yawei
dandelion
Reply #2 - Jul 15th, 2007, 11:45pm
ywguo wrote on Jul 15th, 2007, 8:04pm:
Yawei
The time point step size become loose after 1ms. The simulator use the default algorithm. The steady state mean the circuit have veru quick startup time because it is RC oscillator. The frequncy is about 350KHz.
Pls. comment!
Reply #3 - Jul 20th, 2007, 10:01am
It is better to set the step size in .tran command less than one tenth of the triangular waveform generator. I guess that the step size is too large in your simulation.
Best regards,
Yawei
