Apr 25th, 2025, 11:30pm
Comparison of two capacitor loading configurations (Read 1759 times)
fz2101
Jul 12th, 2007, 8:19am
Hello Everyone,
In many differential designs, there is a question of how to connect the load capacitors.  Gm-C is shown below
as an example.
In school, we were taught that this question depends on whether die area is a constraint and whether fully
symmetric capacitors are available.   If fully symmetric capacitors are available, then the capacitance required
is 4C for the left configuration and 1C for the one on the right (replace the two series caps with one).
However, the loading seen by the common-mode path is 4C on the left and zero on the right, so the common-mode
stability is better for the left side configuration.
My question is which configuration do people use in the industry, for what application and for what reason?
Any other differences (maybe in terms of linearity, noise, etc.) between these two configurations?
Thanks.
ACWWong
Oxford, UK
Re: Comparison of two capacitor loading configurat
Reply #1 - Jul 12th, 2007, 8:38am
the first example allows for common-mode signal filtering as well as differential.
the second examples doesn't perform common-mode filtering, but allows for a lot less area by means of a single capacitance between the outputs of value C (which is often synthesised by two parallel back-to-back capacitors of value 0.5C).
