Sep 29th, 2024, 8:23pm
PLL Loop Filter Capacitor (Read 3558 times)
imtired
Santa Rosa
Jul 12th, 2007, 5:12pm
This is a practical question.
As an amateur PLL designer, the only caps I have ever used are ceramic, usually 0603 or 0805 size.  Can other types of capacitors be used, such as tantalums, or others?
What I really would like to use is some large value (>100uF) and high voltage rating (at least 50V).  With ceramic, I need to stack multiple caps in parallel to achieve this.  Any help would be appreciated.
Thanks.
Berti
Re: PLL Loop Filter Capacitor
Reply #1 - Jul 12th, 2007, 11:46pm
I can't tell you the optimal solution, but according to my experience:
- don't use electrolytic capacitors since those might produce current-spike noise
- tantalum capacitors are more expensive but don't show current-spike noise. But
 ESL and ESR are usually higher than in ceramic capacitors. Therefore you probably
 should include(model) ESL/ESR into your loop filter.
- Cermic capacitors are better suited for high frequencies because they are not constructed
 as a coil. However, usually they are not very linear (distortion), but for a PLL loop filter
 I don't think that this is a issue.
Parallel capacitors always work, but that needs space...
I hope this helps.
imtired
Santa Rosa
Reply #2 - Jul 13th, 2007, 11:22am
Thank you Berti for your all your comments.  That definitely helps me narrow down my options.  Actually I have decided to go with ceramic caps, since I can't find any large capacitors with high enough voltage ratings that can mount on a PCB in a reasonably small area.
